TractorLinks.com
Show Parts for Model:
Re: WD45 won't run
jake in Iowa
03-21-2013 19:23:19
She is up and running good! had to change #2 and #3 around and she fired right off. Adjusted the carb a little and nudged the distributor a bit and she smoothed right out. Old, I didn't just start throwing parts at it, initually I had a weak spark and knowing that I hadn't replaced any ignition parts for awhile I went that route, once I had good spark I noticed that the plugs were dry so I knew I wasn't getting fuel, So I cleaned and put a kit in the carb. Thanks for all your help.
old
03-21-2013 21:34:06
 Re: WD45 won't run in reply to jake in Iowa, 03-21-2013 19:23:19
Well I am old school so I fix many things with out new parts and have found by doing so I can save my self many $$ and many hours of work since a lot of times it is a very simple Duh fix
jake in Iowa
03-22-2013 14:57:00
 Re: WD45 won't run in reply to old, 03-21-2013 21:34:06
I am the same way,usually........but with so many used parts on this tractor already I decided to put some things new on her. Normally these AC's don't require a lot of tinkering I grew up with them, and they would always never fail. But when she wouldn't go I needed to ask some experts here and lo and behold.....a simple fix. This is a great source of info and I read it all the time. thanks.
