Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: WD45 won't run
old
03-21-2013 18:30:25
Firing order is right on the side of the block. As for normal things wrong. You trouble shoot first then throw parts at them not and never the other way around. You first off need a blue/white spark that jumps a 1/4 inch gap or more. Next you need a good steady flow of gas out the carb drain plug for a few minutes. Catch the gas so as to look for water dirt etc. Of course all that has to be there at the right time. Firing order is 1,2,4,3 by the way with the #1 being up by the radiator
jake in Iowa
03-21-2013 19:23:19
 Re: WD45 won't run in reply to old, 03-21-2013 18:30:25
She is up and running good! had to change #2 and #3 around and she fired right off. Adjusted the carb a little and nudged the distributor a bit and she smoothed right out. Old, I didn't just start throwing parts at it, initually I had a weak spark and knowing that I hadn't replaced any ignition parts for awhile I went that route, once I had good spark I noticed that the plugs were dry so I knew I wasn't getting fuel, So I cleaned and put a kit in the carb. Thanks for all your help.
old
03-21-2013 21:34:06
 Re: WD45 won't run in reply to jake in Iowa, 03-21-2013 19:23:19
Well I am old school so I fix many things with out new parts and have found by doing so I can save my self many $$ and many hours of work since a lot of times it is a very simple Duh fix
jake in Iowa
03-22-2013 14:57:00
 Re: WD45 won't run in reply to old, 03-21-2013 21:34:06
I am the same way,usually........but with so many used parts on this tractor already I decided to put some things new on her. Normally these AC's don't require a lot of tinkering I grew up with them, and they would always never fail. But when she wouldn't go I needed to ask some experts here and lo and behold.....a simple fix. This is a great source of info and I read it all the time. thanks.
