Tach Cable 190XT
Guys, I'm in need of a tach cable for a 190XT serial number 19014473DXT (cam shaft hookup). All the aftermarket suppliers I contacted say it's a dealer item only. Called the only AGCO Allis dealer here in Colorado, ordered, sent after a 2 week wait would you believe not the right one. Called them this afternoon to reorder. Was informed that the doors are closing, out of business. Googled dealers and keep going around in circles with no results. Need a source. Thanks
I don't recall anything other than the cable coming off a drive on the back of the alternator.
I think there's a speedometer cable out there that would work. Problem is they're a thing of the past too, so nobody stocks them.
The tach drives in smaller older airplanes were basically the same set up. I've seen in catalogs where they will make them to order.
All that to say that I think you have options, even if you can't get anywhere with AGCO.
If you cant find an oem they are pretty cheap to get made, had a heavy duty one done for a 180puller it was 40 bucks
Thanks guys. Called Ivan and he is sending the proper one. AGCO parts website didn't list/show a cable from the cam, only from the altenator.
