CA engine swap
OldMoIron
Will a D15 series two fit into a CA? Im pretty sure a D14 would fit, is it about the same alterations. Will the rearend and transmission handle it? thanks
The D15 uses an oversized radiator and would likely overheat with a CA radiator. Otherwise, you can swap the engines if you use the CA flywheel and clutch. Your guess is as good as mine about the rear and tranny. LOL Bob
increasing from about 30 HP to 40 HP.... many guys have done that on a B-C- CA tractor without rear end problems.
