Help with WC Drawbar
Looks like someone used AC parts and others to double things up. Original WC had the single U-shaped flat stock welded to the main angle supports, not two of them. Lower parts are just cutoffs added to original.
It looks like a factory S.A.E. drawbar with an extra
bail and some other added reinforcements.
Joe, This is the basic book you should have:
"OPERATING INSTRUCTIONS
MAINTENANCE
and
REPAIR PARTS ILLUSTRATIONS
ALLIS-CHALMERS
MODEL "WC" TRACTOR"
This is the book I copied the page from.
If you want to maintain and repair your
tractor yourself, you should also obtain the
"Service Manual" and the "Dealer Parts Book"
Brian
The drawbar for pto tractor is different than the standard. Sort of a U-shaped part that goes around the front of the drawbar to let the pto shaft go through. Pic is not real clear on that.
Brian,
I have a pdf of form TPL-465M which is dated 5-43 and has illustrations only with parts (no photos). I would imagine that TPL-465N is 1944 or later. There is a form PTL-465G that covers the 39 WC but I haven't found one yet.
