Allis B steering part needed (see pics)
Hey all, I'm trying to help a co-worker with their B. They had tons of slop in the steering, took the gear box apart and found this arm to be wore out where it rides in the worm gear. If anyone would have one or a good place to look would be much appreciated. As you may guess by my screen name, I'm not an orange guy but when it comes to resurrection, I'm color blind LOL!
Thanks
I have a B steering box that had less than 1/8 turn of play in it while on the tractor. The shaft that runs to the steering wheel is rusted and bent at the top but otherwise it is ready to work. I was looking to get $50 for the unit and I can ship it.
Zach
The button on my B was worse than that! I took it to a machinist friend, to get fixed, and he grabbed a bolt and turned the head into a cone shape, using my worm gear, to check the angle, and final diameter with. he removed the old button and replaced it with the bolt, which he cut off to the right length. It works great, but still needs a new seal.
A box off a B should interchange with another box off a B as far as I know, all that would matter would be the alignment of the shafts and the bolt holes on the torque tube. I think that Ross and Gemmer were the brands. The C box is a Ross and turns the other way, so it does not interchange. Send me an email and I can send you pictures of the box I have if you are interested.
Zach
Tracy Martin on the other AC site has a machine shop and can replace the button. He just did two for me $65 each and they look great.
There some on ebay now for 25.00 an change.You can also get them at John Deere.The one for jd model m tractor is the same.
