swapping engines
porsche
New User
I have an International 424 with a IH-C146 gas engine. Does anyone out there know if it will bolt into an Farmall C tractor? Also, if a AC D14 or 15 engine will bolt into an AC C tractor ? Thanks.
As Dick said Yes, but besides using the C flywheel:
The bolt holes in the radiator mount need to be drilled out for the 5/8" bolts on the D10/12/14/15 engine.
The oil fill hole in the hood is in a different position.
The C fan needs to be used.
The air filter will not fit. (I fabricated a tube that comes out of the hood with a K&N filter on it.)
You will need to mount the D.. water temp guage some place.
The muffler hole needs to be moved an inch or so to the left.
Low B with D14 engine
Thanks Bill and Dick for your input. I am working on building a pulling tractor for my nephew. I want to use one of these tractors. Just wanted to see what was possible. Thanks again
