D-12 parts manual
JESSKI
New User
I am trying to find the hydrolic intake hose for my 1964 Allis D-12. It is on the gear pump in the rear of the tractor, above the pto housing, and goes into the rearend housing in an approximate question mark shape, about 6" long, and mabee 3/4"- 1" diameter. my local dealer says it doesn"t exist! however it is there. If I could find a part # for it, I may be able to order a part. hose clamps at each end hold it on. serial # is D12 6124. I belive it is a series III with a 3 point hitch and Traction Booster. Thanks for the help
I ended up putting metal fittings on mine, plus some suction hose, from colliflower, to make a less awkwardly curved section of hose. That hose has been out of stock for the last 8-10 years, IIRR!
