allis wd wireing diagram
What diagram. It is a very simple 3 wire set up if you use a Delco 10si and one of the 3 wires is less then 4 inches long. I can explain it but do not have the diagram but then I can pretty much do it in my sleep. You have a 2 wire plug with #1 and #2 on it. The #2 goes to the charging stud as in the big one on the alternator. The #1 wire goes to the ignition as in to the coil works well with a Radio shack diode 276-1661 cost if $3 for a 4 pack. The big charging stud you use a #10 wire to the amp gauge switch the 2 wires and hook the charging wire to the one you would have switch from the gen
