TractorLinks.com
Show Parts for Model:
Re: Wd electrical help
steve(ill)
02-16-2013 19:24:49
the light switch / charging system/ has nothing to do with the distributor. New switch goes on same way old one comes off.... The present "kill" switch actually grounds the mag to make it stop fireing. The distributor will need a power wire to make it run. The coil is external so you run a hot wire from the ignition sitch to the coil, wire from coil outlet to the distributor, point inside grounds or opens the system to make it spark.
steve(ill)
02-16-2013 19:29:41
 Re: Wd electrical help in reply to steve(ill), 02-16-2013 19:24:49
Ed from mason
02-17-2013 02:34:04
 Re: Wd electrical help in reply to steve(ill), 02-16-2013 19:29:41
I should have put on here that I am going to keep the WD the original 6 volt system with positive to the ground.
steve(ill)
02-17-2013 06:56:51
 Re: Wd electrical help in reply to Ed from mason, 02-17-2013 02:34:04
Yes, my drawing is generic for a 12 volt. If you use the 6, you dont have a regulator, you have a light switch to set the current charge. I was using the drawing more to show the ignition siwtch, coil and distributor. You also might have a positive ground instead of negative, then reverse the terminals on the coil.
steve(ill)
02-17-2013 06:59:32
 Re: Wd electrical help in reply to steve(ill), 02-17-2013 06:56:51
mdm1
02-17-2013 10:54:07
 Re: Wd electrical help in reply to steve(ill), 02-17-2013 06:59:32
I don't mean to highjack this post but my WD-45 wasn't charging (6v) so I grounded the F terminal and it works but it charges on high all the time now. Is it going to hurt anything until I get light switch and console cleaned up and grounded? I don't use it much and not very long when I do.
steve(ill)
02-17-2013 19:39:52
 Re: Wd electrical help in reply to mdm1, 02-17-2013 10:54:07
Grounding the F terminal will make it charge full out. Remember the generator is only 20 amps so it will not hurt for a short period of time. Another thing you can do is put an aligator clip on the end of the ground wire and clip it to the "F" terminal for 15-20 minutes each day when you are running it. Kind of like putting it on a battery charger. If you only run it an hour a week, it dont make much difference. Dont run with it connected for 4-8 hours constant.
