WD45 Price?
ewalker
I am looking for a WD45, I found one that is sitting in the back of a field that needes work. the guy said he will start and show me everything works but it has 1 rear tire that is bad and will not hold air. The tractor is pretty ugly but does seem to be all there. What would be a good price for it?
Around my neck of the woods, it would probably bring about $350.00 to $500.00 at a good auction on a good day.
A good running wd45 would be about 1500 bucks. A new tire is going to cost you about 600. Bid accordingly and buyer beware.
$800 to $1000 with one shot tire and yes about $1500 for a decent one. Where are you located? I have three of them from needing work to turn key, central wisconsin
I paid $500 for a similar one- cosmetics ok, bad rear tire, narrow front, complete, not running, not stuck.
Any extra accesories will drive the price up a bit -- like power steering , spin out rims , wide front, etc , but for the most part I would guess at around $1000.00 if everthing operates as it should. -- good luck
Pretty darned hard to "find one" back in a field and have it not be much more than scrap..
Seems, no-one thinks an AC's "Condition" is worth much..but that is going to change..
I have seen them worn and "Loose",clutch handle flopping either way..etc, etc...
One off a small family Farm with low acreage would be a Premium Tractor..
(That's what I have), off my Grandad's 64 acre family farm..never set outside ..
But, get what you can find and treat it well..!
Ron..
(quoted from post at 11:28:46 02/05/13) $800 to $1000 with one shot tire and yes about $1500 for a decent one. Where are you located? I have three of them from needing work to turn key, central wisconsin
How far from Wausau? Send me a few pics of them. WF/ power steeing? Loader?
[email protected]
