cultivator lift
Hyd lift on a WC never heard of such since they did not have hyds. Now the other type I have one on a parts WC
Hydraulic lift on a WC? I guess it was a dealer installed unit as I have seen some on WCs, in the past. I never say never cause some one is going to have an example contrary to popular belief.
Yes you could add hyds to any thing but no WC came from the factory with hyds but yes maybe there was an aftermarket add on but it would not be by A/C
OK- is it complete? ie, does it have the foot pedal? Olztimers memory says there were two versions re the pedal. OK....early version, used before the WC had the traction release lever......casting on the lift housing had 'notches'....so with a handle, you could crank up the cultivator, or lister, when you dumped it in a bad spot, like.....up against a freaking fence, etc!!!!!! Or stuck in the mud!!! Armstrong was around way before Lance was!
i remember the pedal being on the tractor years ago,i will try to find it.when complete,it will be for sale.
an old guy told me about getting trapped in the corner of the field and having to go up to the yard to get a jack to raise the wheel so he could lift the cultivator and get out of there
some favor!go back to building your "off-green" pull tractor.let me know when it turns ripe!color-blind So-Daker! lol
