TractorLinks.com
Show Parts for Model:
Re: C remote hydrolic outlet?
steve(ill)
02-05-2013 18:24:37
YOu can buy a remote "selection" valve that has 1 input and two outputs. Push the spool in and you get port 1, pull it out you get port 2. It stays where you put it. It mounts to the bottom of the seat and spool points forward toward your right knee. You run one port to your mower lift / 3 point, etc... You run the other port to your implement lift cylinder. As long as the remote cylinder is less than 2 inch diameter and has less than a 10 inch stroke, you have plenty of oil..... YOu can also TEE the implement lift to the rear 3 point cylinder hose. When you lift, the 3 point will stall out and then the implement will lift. NOrmally you put a small chain or strap on the 3 point so it will not drop when you lower the impelement.
Hossman
02-06-2013 16:47:15
 Re: C remote hydrolic outlet? in reply to steve(ill), 02-05-2013 18:24:37
Guys, Thanks so much.Steve I really liked your suggestions. As always you fellers are a big help! Thanks again, Hoss
