Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Freeing stuck tierods??
[Return to Forum]
Hossman
02-05-2013 17:31:34
66.249.56.189
Guys, I have a set of used tierods I recently purchased and need to adjust them back in a bit. Does anyone got any ideas on how to free them up? The ones im replacing have been pretty buggered up by past owner. They took a torch and blew a kerf down the better part of the sleeve to "loosen" them up,complete with the nice slag drip all down the tierods. I have drilled a small hole on the bottom of the "new" tierods to get some penatrant into them and have been fillin with PB blaster.My next trick would be heat. I really dont want to mangle up this good set and wondered if yall had some tips for breaking these loose. As always thanks for any help, Hoss
[Reply]   [No Email]
Bill Rowles
02-11-2013 23:31:11
76.2.232.2
 Re: Freeing stuck tierods?? in reply to Hossman, 02-05-2013 17:31:34
After soaking with PB Blaster, lay the end with the stuck threads on an anvil (or equivalent) and give it a good massage with a heavy hammer while rolling the threaded area around on the anvil with your free hand. That should breakup the rust in the threads without damage.
[Reply]  [No Email]
dej(Jed)
02-11-2013 04:48:14
141.189.251.1
Just buy new ones..........
[Reply]  [No Email]
S.C.
02-10-2013 06:31:12
174.253.0.231
I tried everything on my wd-45 but decided to just buy new ones. The only thing I didn't try was to use an air die grinder with a thin cut off wheel and split the tube to get it free. Make the split on the bottom so if any water gets in it can drain out. You can weld the split back up but it probably wouldn't hurt to leave it, then later if you want to change widths it should be easy.
[Reply]  [No Email]
Hossman
02-06-2013 16:42:51
66.249.56.189
Hey Guys, Thanks so much for the ideas,there still soaking and tommorow gona try the heat and cool trick.If that dont get em gona put the ol air hammer to em. Thanks again, Hoss
[Reply]  [No Email]
Mark-Ia
02-06-2013 07:04:18
207.177.117.7
Heat them up and quick cool them with water. They should almost fall apart.
[Reply]  [No Email]
Leon RCMo
02-05-2013 19:14:36
67.142.182.22
Get after them with a air hammer. Will not beat them up badly.Used to do it all the time when I alighned big trucks.
[Reply]  [No Email]
Mike Neia
02-05-2013 18:08:02
173.215.5.173
If you can hold the tube end try twisting the solid end with a pipe wrench.
[Reply]  [No Email]
Bob Bancroft
02-05-2013 17:40:11
67.140.253.65
Soaking them is good. Heat is good. Working them over with a hammer is good. I don't mean such that you disfigure them, just hammering all over them with a good back up behind the rods.
At the shop where I used to work, we separated stuck PTO shafts by chaining one end to the bottom of the mast assy. of the forklift, and the other to the forks, and lifted!
[Reply]  [No Email]
Hendrik
02-06-2013 03:00:00
194.53.253.51
 Re: Freeing stuck tierods?? in reply to Bob Bancroft, 02-05-2013 17:40:11
Using a forklift is a neat idea. Instead of a (shop)press you a have a "puller", for lack of a better word.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
