TractorLinks.com
Show Parts for Model:
Re: 3-pt. Hitch on a B or C.
Ralphwd45
02-02-2013 23:21:12
I got a 52 B that had a cheap aftermarket 3 pt on it, that was rated at 250 lbs.That rating seemed useless to me , so I bought 2 ford arms, replaced the rockshaft, with a larger diameter shaft, replaced the cylinder, with a 3"x8" cylinder, that was rated for 3000 psi. In later yrs I put a front pump on it, and went to double acting cylinders, and a control valve on the fender. I now haul large round bales, out of the barn, and feed cows with a 3pt hay spear. WARNING use enough weight on the front! I carry 200 lbs of steel weight, and both front tires are loaded with calcium.
steve(ill)
02-03-2013 06:21:36
 Re: 3-pt. Hitch on a B or C. in reply to Ralphwd45, 02-02-2013 23:21:12
yes, i have a couple hundred pounds of weight on the front of mine also.
