Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: D-17 gas vs. 175 gas
[Show Entire Topic]  [Return to Forum]
Skyhighballoon(MO)
01-28-2013 19:43:30
70.230.174.178
Bob - you got it right. The D17 was 7.25:1 compression for the entire run from 1957 to 1967 for gas engines. The Gleaner E combine came out with the same 7.25:1 engine in 1962 somewhere in the middle of production it switched over to 8:1. 1968 EIII Gleaner was also 8:1. 170 was 8:1 and 175 8.25:1. The 175 also got a 1/8" bigger carb too. The G226 engines have codes in the serial number on the block behind the carb to tell you how it came from the factory. M=7.25:1, Z=8:1, V=8.25:1.
Right again that the D17 was 1650 rpm's and the 170 & 175 were 1800 rpms. The earlier WD45 with the 226 engine was 1400 rpms. When Allis first designed the larger 180 tractor it planned to use the 226 gas engine running at 2000 rpms. And yes they were concerned with vibration since it was not counterbalanced as you point out. The prototype met the specs and Allis built 100 of them with the 226 engine. The production versions had vibration problems when they tested them. They went back and retested the prototype and it it was fine...apparently a one of a kind anomaly. So Allis had to back to the drawing board for a few more months and decided to use the 265 6-cylinder gas from the 190 with a smaller carb for the 180 gas (I have one love it!).
Another note on the D17 226 engines...early ones up to SN24000 had a bypass oil filter system ...24001 & up used a full flow oil filter system. Another change I believe in the heads was going to 3/8 reach spark plugs plugs in early D17's to 3/4 reach plugs. But I can't find where that SN break is even in the parts book. Mike
[Reply]   [No Email]
Earl-IL
01-29-2013 09:13:08
50.81.209.158
 Re: D-17 gas vs. 175 gas in reply to Skyhighballoon(MO), 01-28-2013 19:43:30
Thank you for the info. What about the valve size & manifold on the 175? Do you have the D-17 & 175 stock cam specs ?
[Reply]  [No Email]
m.appel
01-29-2013 19:51:10
216.235.173.162
 Re: D-17 gas vs. 175 gas in reply to Earl-IL, 01-29-2013 09:13:08
175 uses a larger cam.i use one in my wc puller.i would have to dig out the spec sheet for the differance.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
