Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: allis g engine compression
leon
01-27-2013 04:06:31
I once tested a smoker G and it tested an even 90 psi in all cylinders. So engines can smoke and still have good compression. I suppose it had valve guide problems.
Dick L
01-27-2013 04:31:21
 Re: allis g engine compression in reply to leon, 01-27-2013 04:06:31
You do have compression rings and an oil ring. It is hard for oil to run up hill to burn and smoke.
leon
01-27-2013 06:08:10
 Re: allis g engine compression in reply to Dick L, 01-27-2013 04:31:21
Wish you'd tilted that camera uphill a bit more, then snapped and posted some pictures of that nice looking G in the background.
Dick L
01-27-2013 06:11:59
 Re: allis g engine compression in reply to leon, 01-27-2013 06:08:10
Look at the whole deal
leon
01-27-2013 07:21:43
 Re: allis g engine compression in reply to Dick L, 01-27-2013 06:11:59
Dick, thanks a bunch for giving access to those photos. From your upload dates, I take it is a recently completed project. It looks very nice. Just doing the restoration is task enough, but adding the photo documentation too is quite an accomplishment and is much appreciated.
Dick L
01-27-2013 08:09:18
 Re: allis g engine compression in reply to leon, 01-27-2013 07:21:43
Over 9 years ago if you call that recent. (:^D
I finished it in November of 2002. I used it to cultivate pumpkins the summer of 2003. I put other pictures in the album at later dates. The second picture was taken after I had repainted it before taking it to a show. My tractors are stored in the big blue barn under the stars.
leon
01-27-2013 05:11:39
Sucked uphill during the intake stroke?
BushogPapa
01-27-2013 13:22:02
 Re: allis g engine compression in reply to leon, 01-27-2013 05:11:39
Yep, they should scrape the excess oil off and away from the compression rings, or it will smoke bad..
Ron..
Dick L
01-27-2013 06:10:06
Could be but I would doubt it. In that engine if the guides were that bad it would be hard for the valves to hold an even 90 pound pressure.
I would sooner think that it had over heated and the oil ring got seized to the piston to let oil get by.
engines like these without water pumps used in factory mules would often over heat from not paying attention to water levels and start smoking. They would replace the rings without any other repair and put the mules back in operation.
Really hard to tell if that would be the problem without being the operator from the start though.
