Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: upgrade on CA hydraulics
[Return to Forum]
Ralphwd45
01-24-2013 15:49:21
66.243.212.58
A little over a yr ago, I bought a CA narrow front, out of a storage unit. It was only slightly stuck, and freed up easily. It was pin hitch, with all of the drawbar missing, but had a home made 3 -pt attempt, with 2--2 way cylinders, hanging off the rear, and they were plugged on one end, and plumbed for single action. After rebuilding the hand clutch, both brakes, and replacing all seals, where I removed the rear housings, I was wondering what to do with the 3 pt.I had an extra, aftermarket 3 pt, from Tonys Tractors, that I didn't need, but was made to hook to a snap coupler. I sawed the loop off the end and welded a short length of sch.40 pipe in place of it. I bought a pin to fit the hole, and put the 3 pt on, then mounted the existing cyl's and plumbed them, for double acting, to a valve that I mounted on the right fender. I ran the return hose under the tranny, and into the fill hole on the tranny, and ran my in hose to the original valve on the pump. I tied the original handle open, with a home made bracket, so it is always open. I tried using the tractor, and liked it, except it needed float on the valve, and didn't have it. Yesterday. I finally replaced the control valve, with one with float, but havent got around to starting it up and trying it. I still want to weight the front with about 200 lbs, but can;t wait to throw the 2-14 mounted on it to see what she will do! I hope it will be close to a modern hydraulic system.
[Reply]   [No Email]
Eldon (WA)
01-25-2013 08:44:49
98.225.11.231
Re: upgrade on CA hydraulics in reply to Ralphwd45, 01-24-2013 15:49:21
I have a C with a front pump and and a tank mounted on the side, with a fabricated 3pt with two way cylinders. I think the front pump is the way to go, always pumping and lower pressure like modern systems.
  [Reply]  [No Email]
willie in mn
01-24-2013 17:08:56
64.12.116.208
Did mine a little bit different. Have loader with hyd bucket tilt. Plumbing the same as yours, but put the valve on left side. Then can pull hand clutch with right hand & operate loader valve with left hand at the same time.
Willie
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
