Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1953 Allis Chalmers WD 45 PTO gearbox
stu (ON)
01-23-2013 07:00:42
Jeff, if you have the AC shop manual, you will have this page. In the diagram of the engine clutch shaft, the PTO gear drives the PTO intermediate gear. The Rear Oil Seal should keep the lightwieght oil in the Hydraulic/belt pulley reservoir from mixing with the heavy oil in the wet clutch/PTO chamber. Of course, seals tend to leak after 55+ years.
The diagram of the torque housing shows that an original PTO cover would have had an oil plug in it. So, if yours is home made, make sure that your PTO drive gear and intermediate gear have their teeth.
Brian G. NY
01-23-2013 07:42:18
 Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to stu (ON), 01-23-2013 07:00:42
Jeff, I have wondered about this for a long time.
The PTO box does go where it is indicated in you diagram. If you go to page 55, you will see another PTO cover shown on the bottom of the trans/diff housing. Don't have a clue why a PTO would be located there as it would defeat the purpose of the hand clutch. Maybe some unusual version of the tractor (industrial or road grader) may have used a special purpose PTO here? Probably will never know!
