TractorLinks.com
Show Parts for Model:
Re: 1953 Allis Chalmers WD 45 PTO gearbox
bg/mo
01-22-2013 16:45:56
The pto transmission and rear diff all share the same oil , so yes there is no fill plug for just the pto. By the clutch pedal inside the frame rail there are two square headed plugs they both need to be filled with oil to fill all the areas.the pto is the lowest point of that oil cavity. I think the belt pulley plug is different.
Jeff Kinnett
01-22-2013 17:09:19
 Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to bg/mo, 01-22-2013 16:45:56
Bg/mo, huge help thank you so much that's the answer I been waiting for that it does share the oil of diff.,tranny,clutch. so the plate bolted on the bottom of the tractor where the PTO gearbox should be, if I take that off to install my PTO gearbox I restored , i will have oil gushing out. is this correct if you answer yes then I have my information thank you so much
bg/mo
01-23-2013 13:38:51
 Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Jeff Kinnett, 01-22-2013 17:09:19
yes if you remove that plate you will have oil, just loosen it and let it drain then install your pto, it will have a drain plug in it then ,you will need a five gallon bucket all together trany pto an differential hold just alittle less than five gal.
Brian G. NY
01-22-2013 19:32:05
A very large portion of that 17 Qts of gear oil will certainly come "gushing" out when you pull that plate off.
If that plate does not have a plug screwed into it (apparently it does not) you can drain some of the oil from the other two drain plugs and finish by loosening the plate and putting a 5 gal pail under it as someone has already suggested.
It will be a little messy; don't you just hate the smell of gear oil when you get it all over yourself? LOL
As stated, check the condition of that intermediate gear in the bottom of the tranny to assure it has no teeth missing. It can, however, be replaced without splitting the tractor.
Brian G. NY
01-22-2013 19:35:45
 Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Brian G. NY, 01-22-2013 19:32:05
After I went back and read all the fine responses by the other guys, I determined that I hadn't added anything of significance! LOL
BushogPapa
01-24-2013 12:53:51
 Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Brian G. NY, 01-22-2013 19:35:45
Be SURE you are going to use a PTO Gearbox for a WD-45 and NOT a WD..they are stronger..
AND, have the upper ears Magnafluxed, to be SURE they are not in any way flawed...
Ron..
