| Allis Chalmers Discussion Forum |
Topic: Re: 1953 Allis Chalmers WD 45 PTO gearbox
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| LeonardWD45
01-22-2013 16:37:28
131.191.110.118
Jeff, if you want to get most of the oil out before taking the block off plate off you can pull the plug for the belt pulley off the right hand side and pull most if not all the oil out from there be careful and have a bucket under it as there is probably some oil behind the plug.Leonard |
| Ralphwd45
01-22-2013 20:10:04
66.243.212.58
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to LeonardWD45, 01-22-2013 16:37:28
| Leonard, you are not as far off as was stated! I just finished changing the clutch in my WD45, and opened up the belt pulley chamber. I tried to use an oil sucker to remove the oil in the chamber, and couldn't make any headway. as fast as I would empty my sucker gun, the oil would refill the chamber. I had to drain the hydraulic, tranny oil, to get the belt pulley chamber empty. |
| LeonardWD45
01-22-2013 20:38:25
131.191.110.118
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Ralphwd45, 01-22-2013 20:10:04
| | Ralph, You just had to get the oil level down below the level of the ball bearing seat on the shaft that transmits the engine power to the rearend through the slip clutch. Leonard |
| willie in mn
01-22-2013 18:02:37
64.12.116.208
| Leonard Error! The belt pulley gear train runs in the hyd oil, completely seperate from PTO/Tran/diff.Jeff Hint- easiest way to get those square headed filler plugs out is to use a 12 point socket that is 1/8 in larger than the square. Eg: 3/4 sq use 7/8 12point. 1/2 sq use 5/8 12point. Then with an extension you can get ratchet above frame rail & be able to turn it easily. Beats the heck out of skinning your knuckles down inside the frame rail. Probable the least messy to drain would be start with the trans drain. Some oil will remain in diff & PTO sections. Then go to PTO, remove 2 bolts at one end of plate, then just loosen, do not remove, the other 2 bolts, let the plate droop & guide oil into catch bucket. HTH, Willie |
| Jeff Kinnett
01-22-2013 17:01:11
66.87.7.48
| so Leonard if you can help explain this I've had a very difficult time understanding this, I'm a first tractor owner, my owners manual tells me that for the transmission, differential and clutch shares all the same oil = 17 quarts 3 drain plugs bottom of tractor, two fill plugs beside the hydraulic filler for these 3. Now speakinging with several tractor owners and the seller of my tractor I have not gotten a clear answer for me if the PTO uses its own oil or shares tranmission oil, and how to fill it. Pto has drain plug Thank you for tip on the belt pulley I will look at that next chance I get it doesn't have a belt pulley but I know I saw a plug on it any help from you would be greatly appreciated |
| LeonardWD45
01-22-2013 20:34:35
131.191.110.118
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Jeff Kinnett, 01-22-2013 17:01:11
| | Jeff, on the right hand frame of the tractor is a large round plug. That is the belt pulley plug. It is a part of the hydrolic (sp) resivour (sp) that is integral to transmission/pto/rear end. The only thing is if you fill the pto/hydrolic resievour up it will drain into the rear end through the roller bearing for the splined shaft. If you have a AC service manual not an I&T it will show a lot better what I am talking about. Leonard PS. Wish I had my service manual here at the house and I would scan the pic's in and show you but they are at the house at the farm. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
