| Author |
[Modern View]
| Jeff Kinnett
01-22-2013 13:33:10
66.87.7.48
purchased a WD 45 with a temporary plate over the PTO gearbox need to know if I take that temporary plate off will oil spill out everywhere ready to restore PTO gearbox, is there a fill plug to add oil for the PTO gearbox or does it get it somewhere else. my AC shop manual and owners manual does not explain |
| stu (ON)
01-23-2013 07:00:42
70.27.27.116
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Jeff Kinnett, 01-22-2013 13:33:10
Jeff, if you have the AC shop manual, you will have this page. In the diagram of the engine clutch shaft, the PTO gear drives the PTO intermediate gear. The Rear Oil Seal should keep the lightwieght oil in the Hydraulic/belt pulley reservoir from mixing with the heavy oil in the wet clutch/PTO chamber. Of course, seals tend to leak after 55+ years.
The diagram of the torque housing shows that an original PTO cover would have had an oil plug in it. So, if yours is home made, make sure that your PTO drive gear and intermediate gear have their teeth. |
| Brian G. NY
01-23-2013 07:42:18
64.22.47.48
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to stu (ON), 01-23-2013 07:00:42
| Jeff, I have wondered about this for a long time. The PTO box does go where it is indicated in you diagram. If you go to page 55, you will see another PTO cover shown on the bottom of the trans/diff housing. Don't have a clue why a PTO would be located there as it would defeat the purpose of the hand clutch. Maybe some unusual version of the tractor (industrial or road grader) may have used a special purpose PTO here? Probably will never know! |
| LeonardWD45
01-22-2013 21:35:07
131.191.110.118
| | Jeff, one last thing, if you pull off the battery box and unbolt and pull the domed plate that is underneath you will access the oil that is used for the pto and hydrolic (sp) system. May be easier than pulling the belt pulley plug. Leonard PS: don't know why I didn't think of this before. |
| stu (ON)
01-22-2013 18:11:16
70.27.27.116
You do not want your intermediate gear looking like this. Make sure it is not one of the reasons the PTO is blanked off.[/img] |
| Jeff Kinnett
01-23-2013 03:21:15
66.87.7.48
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to stu (ON), 01-22-2013 18:11:16
| thank yo, u for information and the pic, I will check this |
| stu (ON)
01-22-2013 17:43:18
70.27.27.116
| You will lose most, but not all, of the oil, as there are compartment walls separating the differential, transmission and wet clutch/PTO compartments.
Since you have the service manual, you will be aware that you need to check for condition of the intermediate gear and that the thickness/ number of gaskets between PTO box and the torque tube determine the backlash between intermediate & idler gears, which is specified at 0.004". If one gasket allows you to engage the PTO without difficulty, I'd stick with that. But, if it is really difficult, you might add another gasket. |
| Jeff Kinnett
01-22-2013 17:51:07
66.87.7.48
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to stu (ON), 01-22-2013 17:43:18
| Stu On, thank you so much, that really helps, i had no ideal of compartments, i will check gaskets as you mentioned. Thanks to all who reponded, positive and extremely helpful info... |
| LeonardWD45
01-22-2013 16:37:28
131.191.110.118
| | Jeff, if you want to get most of the oil out before taking the block off plate off you can pull the plug for the belt pulley off the right hand side and pull most if not all the oil out from there be careful and have a bucket under it as there is probably some oil behind the plug. Leonard |
| Ralphwd45
01-22-2013 20:10:04
66.243.212.58
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to LeonardWD45, 01-22-2013 16:37:28
| Leonard, you are not as far off as was stated! I just finished changing the clutch in my WD45, and opened up the belt pulley chamber. I tried to use an oil sucker to remove the oil in the chamber, and couldn't make any headway. as fast as I would empty my sucker gun, the oil would refill the chamber. I had to drain the hydraulic, tranny oil, to get the belt pulley chamber empty. |
| LeonardWD45
01-22-2013 20:38:25
131.191.110.118
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Ralphwd45, 01-22-2013 20:10:04
| | Ralph, You just had to get the oil level down below the level of the ball bearing seat on the shaft that transmits the engine power to the rearend through the slip clutch. Leonard |
| willie in mn
01-22-2013 18:02:37
64.12.116.208
| Leonard Error! The belt pulley gear train runs in the hyd oil, completely seperate from PTO/Tran/diff.Jeff Hint- easiest way to get those square headed filler plugs out is to use a 12 point socket that is 1/8 in larger than the square. Eg: 3/4 sq use 7/8 12point. 1/2 sq use 5/8 12point. Then with an extension you can get ratchet above frame rail & be able to turn it easily. Beats the heck out of skinning your knuckles down inside the frame rail. Probable the least messy to drain would be start with the trans drain. Some oil will remain in diff & PTO sections. Then go to PTO, remove 2 bolts at one end of plate, then just loosen, do not remove, the other 2 bolts, let the plate droop & guide oil into catch bucket. HTH, Willie |
| Jeff Kinnett
01-22-2013 17:01:11
66.87.7.48
| so Leonard if you can help explain this I've had a very difficult time understanding this, I'm a first tractor owner, my owners manual tells me that for the transmission, differential and clutch shares all the same oil = 17 quarts 3 drain plugs bottom of tractor, two fill plugs beside the hydraulic filler for these 3. Now speakinging with several tractor owners and the seller of my tractor I have not gotten a clear answer for me if the PTO uses its own oil or shares tranmission oil, and how to fill it. Pto has drain plug Thank you for tip on the belt pulley I will look at that next chance I get it doesn't have a belt pulley but I know I saw a plug on it any help from you would be greatly appreciated |
| LeonardWD45
01-22-2013 20:34:35
131.191.110.118
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Jeff Kinnett, 01-22-2013 17:01:11
| | Jeff, on the right hand frame of the tractor is a large round plug. That is the belt pulley plug. It is a part of the hydrolic (sp) resivour (sp) that is integral to transmission/pto/rear end. The only thing is if you fill the pto/hydrolic resievour up it will drain into the rear end through the roller bearing for the splined shaft. If you have a AC service manual not an I&T it will show a lot better what I am talking about. Leonard PS. Wish I had my service manual here at the house and I would scan the pic's in and show you but they are at the house at the farm. |
| Meangreen
01-22-2013 13:43:51
98.188.136.175
| | There is supposed to be the drain plug for that part of the tractor at the bottom of the PTO gear box, so yeah there is oil right behind that plate. The fill holes are located inside the frame on left hand, carb side, of the tractor. The plugs in the holes have a square head on them. One is large and the other small with the larger one being closer to the rear of the tractor. |
| Jeff Kinnett
01-22-2013 13:54:45
66.87.7.48
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Meangreen, 01-22-2013 13:43:51
| so 5 gallon bucket under the temporary plate when I take it off to capture oil that comes out, now my shop and service manual show filler plugs but none for the PTO gearbox you said it's inside the frame, if I'm standing in front of the carburetor is fill plug for pto around this area |
| bg/mo
01-22-2013 16:45:56
166.216.128.78
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Jeff Kinnett, 01-22-2013 13:54:45
| The pto transmission and rear diff all share the same oil , so yes there is no fill plug for just the pto. By the clutch pedal inside the frame rail there are two square headed plugs they both need to be filled with oil to fill all the areas.the pto is the lowest point of that oil cavity. I think the belt pulley plug is different. |
| Jeff Kinnett
01-22-2013 17:09:19
66.87.7.48
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to bg/mo, 01-22-2013 16:45:56
| Bg/mo, huge help thank you so much that's the answer I been waiting for that it does share the oil of diff.,tranny,clutch. so the plate bolted on the bottom of the tractor where the PTO gearbox should be, if I take that off to install my PTO gearbox I restored , i will have oil gushing out. is this correct if you answer yes then I have my information thank you so much |
| bg/mo
01-23-2013 13:38:51
204.54.154.68
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Jeff Kinnett, 01-22-2013 17:09:19
| yes if you remove that plate you will have oil, just loosen it and let it drain then install your pto, it will have a drain plug in it then ,you will need a five gallon bucket all together trany pto an differential hold just alittle less than five gal. |
| Brian G. NY
01-22-2013 19:32:05
64.22.47.48
| A very large portion of that 17 Qts of gear oil will certainly come "gushing" out when you pull that plate off. If that plate does not have a plug screwed into it (apparently it does not) you can drain some of the oil from the other two drain plugs and finish by loosening the plate and putting a 5 gal pail under it as someone has already suggested. It will be a little messy; don't you just hate the smell of gear oil when you get it all over yourself? LOL As stated, check the condition of that intermediate gear in the bottom of the tranny to assure it has no teeth missing. It can, however, be replaced without splitting the tractor. |
| Brian G. NY
01-22-2013 19:35:45
64.22.47.48
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Brian G. NY, 01-22-2013 19:32:05
| After I went back and read all the fine responses by the other guys, I determined that I hadn't added anything of significance! LOL |
| BushogPapa
01-24-2013 12:53:51
173.88.51.117
Re: 1953 Allis Chalmers WD 45 PTO gearbox in reply to Brian G. NY, 01-22-2013 19:35:45
| Be SURE you are going to use a PTO Gearbox for a WD-45 and NOT a WD..they are stronger.. AND, have the upper ears Magnafluxed, to be SURE they are not in any way flawed... Ron.. |
