Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: D 14 Power Steering?
Bob Bancroft
01-13-2013 09:52:45
Sure. As old says, power steering was available starting with the WD45. It's just not very common on the D14. Consider yourself fortunate. Unlike the WD, the D series without power steering was a challenge!
Too Far Gone
01-13-2013 14:19:01
 Re: D 14 Power Steering? in reply to Bob Bancroft, 01-13-2013 09:52:45
Yes,Ive seen the pulley,and pump on the wd-45 applications,but this sucker is fed with steel lines from the hydraulic pump on the motor to the steering motor up under the front end.(nothing like a wd-45)not even close
Bob Bancroft
01-13-2013 15:31:11
 Re: D 14 Power Steering? in reply to Too Far Gone, 01-13-2013 14:19:01
I don't believe anyone was trying to say the WD45 and D series steering were the same. Just that since power steering was offered prior to the D series, it wouldn't make sense for it to not be available later.
old
01-13-2013 14:51:55
Same set up as on some D-17s and there was a few different power steering set up used over the years
Too Far Gone
01-13-2013 15:15:25
 Re: D 14 Power Steering? in reply to old, 01-13-2013 14:51:55
It works pretty well
old
01-13-2013 15:29:48
 Re: D 14 Power Steering? in reply to Too Far Gone, 01-13-2013 15:15:25
Yep know what you mean. The one on my D-17 leaks some and I have yet to figure out where it leaks so I have to fill it up a couple time a year but then I only use the tractor during ay season
Too Far Gone
01-13-2013 15:44:46
 Re: D 14 Power Steering? in reply to old, 01-13-2013 15:29:48
They're a pretty sweet ol tractor for the money
old
01-13-2013 15:55:14
 Re: D 14 Power Steering? in reply to Too Far Gone, 01-13-2013 15:44:46
This D-17 I have was a fence row dead tractor when I got it. When I first got it home it seemed like the engine was full of mouse nest as in 3 or the 4 cylinders had lots of straw etc in them. I did my normal ATF soak and got it to slowly fire on one cylinder then 2 then 3 and now you could not tell it was that bad off. It does look like it got pretty hot at one time also as in maybe a fire or some such thing but boy does it run and start well now
Copyright © 1997-2015 Yesterday's Tractor Co.
