Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1949 ac wd
stu (ON)
01-08-2013 19:28:40
All one oil reservoir for differential, transmission, wet clutch & PTO. Most usually leaks past seal of PTO output shaft or actuator shaft or seal of hand clutch shaft. But could leak past rear axle seals into & out brake cavity or forward past seal into hydraulic fluid reservoir, although this is less likely as hydraulic oil shoud be thinner and with pulses of pressure when arms drop, more likely to leak into wet clutch.
There also are drain plugs beneath the diff, trannny & PTO.
Where are the drips?
arnold wirth
01-09-2013 08:09:43
 Re: 1949 ac wd in reply to stu (ON), 01-08-2013 19:28:40
thanks for reply looks like it is pto seal how big a job to replace it
