Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 1949 ac wd
[Return to Forum]
arnold wirth
01-08-2013 18:22:49
71.34.169.37
losing oil from tranmission could it be going into rear end or ????
[Reply]   [No Email]
stu (ON)
01-09-2013 11:22:37
70.27.27.116
 Re: 1949 ac wd in reply to arnold wirth, 01-08-2013 18:22:49
Here's an old post:
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ac&th=34442
If you have the original Chicago Rawhide seal, the new neoprene seal will look much thinner and may not last as many decades. Service manual calls for removing bearing cage in order to remove old seal and press in new one. Not to say you couldn't pry old one out with seal remover and slip new one over stub shaft of PTO. Either way remove any burrs from stub shaft. You will have to drain a lot of oil to get PTO empty. Should be 80W90; if it's dirty, replace it. Manual calls for use of sealer on outside of seal, which would mean good cleanup of seal seat. Bearing cage is separated from housing by layers of metal shims; these control end play of stub shaft and you want a free rolling fit, so don't damage them when you remove the bearing cage.
Not very tricky.
[Reply]  [No Email]
stu (ON)
01-08-2013 19:28:40
70.27.27.116
All one oil reservoir for differential, transmission, wet clutch & PTO. Most usually leaks past seal of PTO output shaft or actuator shaft or seal of hand clutch shaft. But could leak past rear axle seals into & out brake cavity or forward past seal into hydraulic fluid reservoir, although this is less likely as hydraulic oil shoud be thinner and with pulses of pressure when arms drop, more likely to leak into wet clutch.
There also are drain plugs beneath the diff, trannny & PTO.
Where are the drips?
[Reply]  [No Email]
arnold wirth
01-09-2013 08:09:43
71.34.169.37
 Re: 1949 ac wd in reply to stu (ON), 01-08-2013 19:28:40
thanks for reply looks like it is pto seal how big a job to replace it
[Reply]  [No Email]
chalmersbob(pa)
01-08-2013 19:27:51
173.62.131.134
The transmission and rear are 1 cavity. Is it leaking from a rear seal around the brakes?
LOL Bob
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
