Ray Helman
New User
engine to tranny
Tool and die man that does work for me
His dad was one of the first men in michigan to fab dune buggies, they know it all. want to do another tractor after this one
A friend of mine did a very similar conversion to his B. By using an electric pusher fan on the front side of the radiator he did not need to lengthen his hood. however he did cut a hole in the top of the hood to allow the air cleaner to stick through. my friend drilled the original tractor flywheel to match the bolt pattern of the Chevy crank. This allowed him to also use the original tractor starter and beefed up tractor clutch. Due to the higher RPMs of the V8 I think a custom steel flywheel would be more prudent.Thanks for sharing your photos and keep us up to date on your progress. Kip
Amazing project!!! ......... those model B final drives won't take much abuse ........ be careful with all that torque.
Kip, they exploded one in Springfield IL when the stock flywheel could not take the RPM.
