| Allis Chalmers Discussion Forum |
Topic: Re: fly wheel timing port?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| steve(ill)
01-06-2013 14:27:30
74.36.165.175
not sure, but i thought the inspection hole was on the bottom. Normally you "time" the motor at TDC as they startup / fire at that point. After the motor is running, the spark will advance to 30 degrees with the magnito or distributor weights. You can see it fire at "F" later with a timing light. |
[Reply] [No Email] | |
| Dick L
01-06-2013 15:18:28
50.51.132.156
Re: fly wheel timing port? in reply to steve(ill), 01-06-2013 14:27:30
| | Any engine starts out being timed to TDC on number one cylinder on the compression stroke without the engine running. When running you will find the F (fire) line with a timing light. All engines are not timed at 30 degrees advanced but yours is. There is a procedure where you time the engine using the fire line when using a magneto to set the magneto without loading the spring. Some get confused between the two. They both come out the same if you understand which one you are using and what you are needing at the end. Starting with the TDC means you will have to check your spark on the compression stroke after assembly to make sure you are not 180 degrees off. In doing so you will know you are on target. |
| Ralphwd45
01-06-2013 22:36:51
66.243.215.13
Re: fly wheel timing port? in reply to Dick L, 01-06-2013 15:18:28
| I got the engine back in by dark tonight, and buckled up to the mounts, If the temp holds till tomarrow, I plan to install the govener and dist, then We will see if I understand correctly, what you guys have told me |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
