TractorLinks.com
Show Parts for Model:
Re: Allis Chalmers C Rear Axle Oil Seal
Ralphwd45
01-06-2013 14:01:56
This is a real good time to replace the seals around the shafts where they enter the hydraulic fluid housing. they will leak oil into the brake area and run thru the axle housing, onto the ground. Dick L and OLD, also know quite a bit about these, if they answer. Poasting is real slow today, so they may be reluctant to reading the forum.
Larry Hardesty
01-07-2013 14:05:45
 Re: Allis Chalmers C Rear Axle Oil Seal in reply to Ralphwd45, 01-06-2013 14:01:56
Ralph, Are you referring yo replacing the seals (206449 and 800351) on the main shaft (223427)? Will I have to take off the final drive housing? It looks like a heavy piece. If I have to remove it, any idea of its weight? I need to check to see if those seals are available via Yesterday's tractors or the local AGCO dealers. Thanks
