| Allis Chalmers Discussion Forum |
Topic: fly wheel timing port?
[Return to Forum]
| Author |
[Modern View]
| Ralphwd45
01-06-2013 13:43:45
66.243.215.13
I removed the engine from my wd45, to replace the clutch and pressure plate. was ready to lower it back in, and buckle it up, when I decided to find the flywheel timimg marks, and paint them white with a paint pencil, so I can see them easier. I found two places with a mark with an F on them, and they are directly oppisite each other. 180 deg. I brought the number one piston up on compression stroke, to the top, by feel, and looked at my marks, to locate where in the bell housing, that the timing hole should be. No holes anywhere in my bell housing when viewed from outside, or inside. IT manual says view timing mark thru hole on lower bell housing.(BS) I looked at 3 small Allis's and the B, C, &CA, all had the hole in the bell on the left side . I gave up and am here on the forum asking for help, also I removed the govener with distributer attatched, so I will have to retime it. If the hole is in the inspection plate, on the bottom of the bell housing, how do you use it with the timing mark 30 deg higher up on the flywheel? |
[Reply] [No Email] | |
| funky_g00
01-06-2013 20:37:18
108.167.4.217
Re: fly wheel timing port? in reply to Ralphwd45, 01-06-2013 13:43:45
| Turn the engine until see the TDC line NOT the Fire line in the inspection hole on bottom of bell housing. There should be a line or notch front and center of inspection hole. Install magneto set to #1 cylinder. (remember to rotate the mag backwards to set it to #1 or else your timing will be off). Start tractor, once started, check with timing light, the Fire line should now be visible thru inspection hole. Adjust accordingly. This is the procedure for framed allis"s (WC,WD,WD45). All others are considered frameless and use the side inspection hole but basically timed the same. |
| anallisguy
01-06-2013 16:10:13
68.32.141.76
| a couple of inches away from the fire marks you will find a tdc line, probably not marked. will be on the bottom when on tdc, and possibly not visible thru the opening in the bottom of the bell housing. the set screw that holds the crank pulley will be at the bottom of the crank rotation at 6 oclock when you are on tdc. |
| Bob Bancroft
01-06-2013 14:33:49
97.73.64.149
| As I recall, they were timed through the bottom hole. Seems like there's a little chisel mark down there somewhere. There should be TDC and a firing mark. |
| steve(ill)
01-06-2013 14:27:30
74.36.165.175
| not sure, but i thought the inspection hole was on the bottom. Normally you "time" the motor at TDC as they startup / fire at that point. After the motor is running, the spark will advance to 30 degrees with the magnito or distributor weights. You can see it fire at "F" later with a timing light. |
| Dick L
01-06-2013 15:18:28
50.51.132.156
Re: fly wheel timing port? in reply to steve(ill), 01-06-2013 14:27:30
| | Any engine starts out being timed to TDC on number one cylinder on the compression stroke without the engine running. When running you will find the F (fire) line with a timing light. All engines are not timed at 30 degrees advanced but yours is. There is a procedure where you time the engine using the fire line when using a magneto to set the magneto without loading the spring. Some get confused between the two. They both come out the same if you understand which one you are using and what you are needing at the end. Starting with the TDC means you will have to check your spark on the compression stroke after assembly to make sure you are not 180 degrees off. In doing so you will know you are on target. |
| Ralphwd45
01-06-2013 22:36:51
66.243.215.13
Re: fly wheel timing port? in reply to Dick L, 01-06-2013 15:18:28
| I got the engine back in by dark tonight, and buckled up to the mounts, If the temp holds till tomarrow, I plan to install the govener and dist, then We will see if I understand correctly, what you guys have told me |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
