TractorLinks.com
Show Parts for Model:
Re: Allis Chalmers C Rear Axle Oil Seal
Ted in NE-OH
01-06-2013 12:10:27
The whole axle has to be removed. The cover in the inside of the bull gear housing must be removed, then the bolt with shims is removed, then the axle is either driven or pushed out. Then the outer bearing is removed and the oil seal is put on the axle and the process is reversed. I forgot inside the bull gear housing is a big nut the holds the bull gear on the axle that must be removed, I use big channel lock pliers on that.
Larry Hardesty
01-07-2013 14:11:29
 Re: Allis Chalmers C Rear Axle Oil Seal in reply to Ted in NE-OH, 01-06-2013 12:10:27
Ted, Thanks, by whole axle, are you referring to the flanged axle that connects to the wheel rim? And not the shaft assembly coming out of the transmission. I suppose per Ralph, I should replace the seals on it too but looks like a lot more effort. I have the pictures from the parts book but I don't see the big nut holding the bull gear on the housing. Thanks for the heads up on it.
Larry
