| Allis Chalmers Discussion Forum |
Topic: Allis Chalmers C Rear Axle Oil Seal
[Return to Forum]
| Author |
[Modern View]
| Larry Hardesty
01-06-2013 11:34:00
74.38.128.240
This is the continuing saga of my 1942 Allis Chalmers C. I have the back wheels off, and it looks like while I do I should replace rear axle oil seals since there is quite a bit of oil leaked onto the rear wheels. I do have the service manual and parts manual, but after 70 years, some things do not come apart like the manual says they will. Is there any trick I should know about taking off the flanged rear axle and replacing the oil seals? Looks like there is a spacer seal (part 295510) and an oil seal (part 206459). Where can I purchase them? And, anything else I should look for or check on while I have the flanged rear axle off? Thanks in advance. Larry |
| Ralphwd45
01-06-2013 14:01:56
66.243.215.13
Re: Allis Chalmers C Rear Axle Oil Seal in reply to Larry Hardesty, 01-06-2013 11:34:00
| This is a real good time to replace the seals around the shafts where they enter the hydraulic fluid housing. they will leak oil into the brake area and run thru the axle housing, onto the ground. Dick L and OLD, also know quite a bit about these, if they answer. Poasting is real slow today, so they may be reluctant to reading the forum. |
| Larry Hardesty
01-07-2013 14:05:45
74.38.128.240
Re: Allis Chalmers C Rear Axle Oil Seal in reply to Ralphwd45, 01-06-2013 14:01:56
| Ralph, Are you referring yo replacing the seals (206449 and 800351) on the main shaft (223427)? Will I have to take off the final drive housing? It looks like a heavy piece. If I have to remove it, any idea of its weight? I need to check to see if those seals are available via Yesterday's tractors or the local AGCO dealers. Thanks |
| Ted in NE-OH
01-06-2013 12:10:27
72.16.19.80
| The whole axle has to be removed. The cover in the inside of the bull gear housing must be removed, then the bolt with shims is removed, then the axle is either driven or pushed out. Then the outer bearing is removed and the oil seal is put on the axle and the process is reversed. I forgot inside the bull gear housing is a big nut the holds the bull gear on the axle that must be removed, I use big channel lock pliers on that. |
| Larry Hardesty
01-07-2013 14:11:29
74.38.128.240
Re: Allis Chalmers C Rear Axle Oil Seal in reply to Ted in NE-OH, 01-06-2013 12:10:27
| | Ted, Thanks, by whole axle, are you referring to the flanged axle that connects to the wheel rim? And not the shaft assembly coming out of the transmission. I suppose per Ralph, I should replace the seals on it too but looks like a lot more effort. I have the pictures from the parts book but I don't see the big nut holding the bull gear on the housing. Thanks for the heads up on it. Larry |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
