Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: AC C rear wheel studs
old
01-05-2013 11:08:43
I am sure there is a way to do it but you do have o hold your mouth just right stand on one leg and move the hub and bull gear just right to do it. Ya not much help but I bet if you try moving the hub a little at a time you will find that one sweet spot that will let it fall out
Noah in IA
01-05-2013 16:57:15
 Re: AC C rear wheel studs in reply to old, 01-05-2013 11:08:43
Thanks to all for your suggestions! I think I'm just going to go ahead and tack-weld a nut to the backside and run a bolt through...if i ever get my hands on that engineer! (probably the same guy that designed the brake band pin nightmare on this same tractor - haha)
...by the way if any of you guys remember my questions about the coolant contaminated motor oil in this same tractor - i followed your tips (replaced the wet sleeve o-rings) and now have the tractor running again with no coolant problem! thanks again for all your help over the past few months!
-noah
old
01-05-2013 17:12:13
 Re: AC C rear wheel studs in reply to Noah in IA, 01-05-2013 16:57:15
Yep know about the o-ring sleeve problems and BTDT.
Copyright © 1997-2015 Yesterday's Tractor Co.
