TractorLinks.com
Show Parts for Model:
Re: Slight miss WD
Chris hauser
01-04-2013 17:37:26
Ok thank you
old
01-04-2013 17:51:15
 Re: Slight miss WD in reply to Chris hauser, 01-04-2013 17:37:26
Ok so if you choke it some does it help or hurt the way it runs?? If it help yes maybe just need to open up the main jet a little bit. If it does not help or makes it worse then could be you need to check the air cleaner and make sure it is not full of water and dirt. Or you may need to adjust the valves since once warmed up it has the miss and that can be a sign of a valve that needs to be adjusted
Chris hauser
01-04-2013 18:00:24
 Re: Slight miss WD in reply to old, 01-04-2013 17:51:15
I Havent tried to slightly rechoke it once its warmed up I will try that next time I get it running, And check the Air cleaner thanks for the Info
old
01-04-2013 18:29:47
 Re: Slight miss WD in reply to Chris hauser, 01-04-2013 18:00:24
The old oil bath air cleaners on tractors are one of the most neglected parts on a tractor. I have seen people that when I ask say I did not know they had that
Chris hauser
01-04-2013 18:37:37
 Re: Slight miss WD in reply to old, 01-04-2013 18:29:47
Yea I will be checking it out I'm hoping its easy to get it figured out. It starts easy but I'm just hoping its simple I don't want to have a dead cylinder
old
01-04-2013 18:43:05
 Re: Slight miss WD in reply to Chris hauser, 01-04-2013 18:37:37
Many misses are odd things. Another thing to try is find the cylinder that has the miss then move the spark plug in that cylinder to another cylinder and see if the miss goes with the plug
Ralphwd45
01-06-2013 14:16:30
 Re: Slight miss WD in reply to old, 01-04-2013 18:43:05
I had to replace the manifold gaskets, to remove a presistant miss, on my WD45. Not a bad job, (if no studs twist off)
old
01-06-2013 14:23:01
 Re: Slight miss WD in reply to Ralphwd45, 01-06-2013 14:16:30
Ya and those type of misses can be found with a propane torch or a can of carb cleaner spray
