b transmission
jeff-h01
You all have helped me with a lot of stuff...one more question...my dad took off the cover on the side of the Trans and the fork that shifts won't go back in correctly...any info or pics of it would be helpful as i have a guy coming to look at it tomm...thanks
get both gears in neutral and lined up carefully with the forks and the cover will slide right on. I have had a couple of them off and back on over the years.
Zach
Sounds like you have some gears not as they should be and the shifter not where it needs to be. Those shifters on the B/C can be a real pain in the back sides to get in and almost takes two people at times to do so
