looking at a d19 diesel that has been setting in a mans yard for the last 15 years un touched. I know it is gonna need new tires, new seat, and dont know if it is stuck or not. sheet metal is all there and looks good. With that said what do you guys think it might be worth? thanks jordan
Let nodody kid you.The d19 diesel is hard to find and quite impressive restored and blowin black smoke again.Ive watched gassers at auctions sunk in to the rims bring 900 and up.AC Engines are plentiful from combines for $750,and 18.4-34 tires are easy to come by on old clamp on duals
If it has sat that long I will bet it has major problems. The early D-19 used sub par parts and had a weak rear end and other such things and could well be why it is and has been sitting. Also they had the jumping out of gear problems like the 190XT had. Also that Rooser Master injection pump has seal problems and if a seal want bad dumped diesel in the oil pan and in turn blow the engine. As it sits figure out how heavy it is and offer what ever it would bring as scrap iron. By the way not saying to scrap it but that is about all it is worth if it has sat that long
D19 diesels do bring good money now if they are good running condition, this one will need a ton of work just to get it running, its setting for a reason, 1000 bucks Tops! !!
