Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: D14 HAND CLUTCH?
Bob Bancroft
01-01-2013 06:38:38
First- get yourself a reprint of the original AC service manual so you have the info. right there. I'll hit some high points. Access is through the side cover there by the handle. There are 9 shim stacks total, three lined up, in each of three places around the perimeter of the clutch. The total thickness of each set of three needs to always be the same. To tighten a clutch, you take a few shims out of one side, and put the same amount back in the middle. However the shims in the middle(between the two plates dividing the halves of the clutch) are longer. A good old AC dealer will have a drawer full somewhere. Maybe you'll have to buy new. It's a trial and error kind of thing, and sounds a lot more complicated than it really is. Do one side, then the other. If by moving shims you can't get it to snap and stay, then something is worn to the point of needing to be replaced.
Too Far Gone
01-01-2013 07:12:38
 Re: D14 HAND CLUTCH? in reply to Bob Bancroft, 01-01-2013 06:38:38
Thanks to both of you guys.I'll try the set screw fist.I know a service manual would be great,but I dont have one and your a big help.
JMS/.MN
01-01-2013 09:15:33
 Re: D14 HAND CLUTCH? in reply to Too Far Gone, 01-01-2013 07:12:38
I don't know about the 201 manual, but the I&T AC- 17 has those adjustments.
old
01-01-2013 09:52:05
 Re: D14 HAND CLUTCH? in reply to JMS/.MN, 01-01-2013 09:15:33
As per the back cover of the AC-11 the I-T 201 covers the D14-to the 175 and all between. It does not even have a AC-17 listed and the back cover of the AC-202 does not list an I-T AC-17 either
JMS/.MN
01-01-2013 11:31:52
 Re: D14 HAND CLUTCH? in reply to old, 01-01-2013 09:52:05
I wonder if they don't print the AC-17 anymore. Mine is maybe 30 years old. Probably bought it about '83/84 when I got my second D17.
old
01-01-2013 11:37:19
 Re: D14 HAND CLUTCH? in reply to JMS/.MN, 01-01-2013 11:31:52
Could well be that the AC-17 is no longer available and was replaced by the A-C 201 which list the D-14, D-15, D-17, D-10, D-12, 160 170 and the 175 all series of all of them. May well be like the AC202 I have which is about a 1/2 inch thick and covers from the D-21 up to the 7080 and all between which I'll not list because it is a long list as in 16 models and ALL series in them
