| Allis Chalmers Discussion Forum |
Topic: Baffel in WD45 belt pulley gear compartment
[Return to Forum]
| Author |
[Modern View]
| Ralphwd45
12-31-2012 13:01:11
71.161.78.38
What in the world, is that tin baffel for, in the belt pulley housing, and how come it is held in place by a 90 deg. brass fitting? It looks like someone disconected a line and threw it away. can;t figgure why a line there, or where it might have went to. My IT manual doesn;t address it, but does show it without a line attatched. The Jensales manual does simular! I want to close it up with a new gasket, and don;t want to do that till I know more. |
| Duey (IA)
12-31-2012 20:33:17
216.248.103.176
Re: Baffel in WD45 belt pulley gear compartment in reply to Ralphwd45, 12-31-2012 13:01:11
| If you tie up the rear lift arms, the cylinders stay full of oil. If you then fill up the hydraulic reservoir, be very careful if you lower the arms later. There is a vent for the hydraulic reservoir under the inspection plate under the starter (one of the little traps that AC engineering created.) (usually a brass elbow installed in a threaded hole) This vent will squirt any over filled oil directly onto the foot clutch!!! On my tractors, I have plugged this vent with a pipe plug. Then I drilled a hole and welded a pipe coupler in the inspection plate under the starter, at an angle, to miss the starter and installed a cylinder vent. The result is a dry clutch as oil fumes and any overfill are vented to the outside. |
| S.C.
12-31-2012 16:12:13
174.255.102.159
| That is a splash guard to keep oil away from the elbow which acts as a breather. Don't plug this hole. The opening in the elbow should be down. As things warm up and the oil and air inside expand this breather allows air to escape and keeps oil from leaking past the seals. Every gearbox on those tractors is vented. The transmission and rearend vents through the gear shift tower. The rubber boot covers a groove on the front of the casting. Both final drives have small vent holes below the input shafts that vents into the cast tube. |
| Brian G. NY
12-31-2012 13:37:01
64.22.46.132
|   It has never been clear to me either; somehow the vent apparently allowed oil into the clutch housing which caused it to slip. They apparently then came up with this tube to reroute the vent. See if this info clears anything up. |
| Ralphwd45
12-31-2012 14:09:01
71.161.78.38
Re: Baffel in WD45 belt pulley gear compartment in reply to Brian G. NY, 12-31-2012 13:37:01
| Well according to your schematic, If there is no line going to the 90 fitting, then it must be supposed to be turned down, so oil can't enter. I had a lot of oil inside my bellhousing, because of the seal leaking around the jack shaft. I got it cleaned out and went to Bearings INC. and bought a seal that works well. the old seal didn't have a number on it, and my manuals didn't list a part number, so I took the old seal in and had it measured. They used a co2 fire extinguisher to quick freeze the rubber on the old seal, so it would not depress the rubber when using their calipers. I am going to post the replacement seal number here for anyone that might need to replace one. It is a CR12830, and fits snugly on the shaft, and is a press fit in the bellhousing recess.Acording to their measurements, it measures 1.281 ID and costs $6.49+ tax. |
| McBride
12-31-2012 13:44:33
74.70.171.169
| | I never knew either but the parts book says: NOTE: These Items used in production Eff. S/N 23362 & Up. When installing these or 70224669 FILLER ASY. BAFFLE, 70224575 must also be added in Belt Pulley Gear Housing if not already |
| Ralphwd45
12-31-2012 14:15:08
71.161.78.38
Re: Baffel in WD45 belt pulley gear compartment in reply to McBride, 12-31-2012 13:44:33
| I wonder why they did't just put a pipe plug in the hole, and put a rain proof pressure relief hole in the hatch cover. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
