TractorLinks.com
Show Parts for Model:
Re: D15 series 2 gas won't fire
old
12-30-2012 19:43:32
What you did was hit the battery side stud on the solenoid with the wrench so that says you have power on that side now you need to find out if you can get it to the other side. That solenoid should have 1 or 2 small studs also and one will have a wire on it. You can take a short jumps from that stud to the battery side of the solenoid and see if it turns over that way and if it does then the key switch or the wire from it is bad
M. Johnston
12-30-2012 20:18:25
 Re: D15 series 2 gas won't fire in reply to old, 12-30-2012 19:43:32
Thanks. Il try that tomorrow and go from there.
old
12-30-2012 21:18:23
 Re: D15 series 2 gas won't fire in reply to M. Johnston, 12-30-2012 20:18:25
Post back if you need more info. Always happy to help if I can
M. Johnston
01-01-2013 10:41:22
 Re: D15 series 2 gas won't fire in reply to old, 12-30-2012 21:18:23
Replaced solenoid and started right up in this 5 degree weather
old
01-01-2013 11:09:08
 Re: D15 series 2 gas won't fire in reply to M. Johnston, 01-01-2013 10:41:22
Good to here you got it fixed
