| Allis Chalmers Discussion Forum |
Topic: Re: WD starter switch is sparking
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Ted J
12-29-2012 04:36:08
68.115.53.205
If it happens frequently, you can split the tractor and move the ring gear. You can move it 90 degrees, but I would rather install a new one. Did you REALLY clean up the starter before you put it back together? The bendix needs to slide on the starter real good. Crud on the shaft can keep it from coming back, a bad spring or the teeth could be bad on the bendix or on the ring gear. Things to look out for. |
| PTG in MN
12-30-2012 10:12:09
174.157.202.241
Re: WD starter switch is sparking in reply to Ted J, 12-29-2012 04:36:08
| | Good points. I cleaned it to make sure it came back ok. However I"m sure I could have been more detailed. If it happens again, or on a warmer day, what do you guys recommend using on the shaft to clean it good. Carb cleaner? Also what is the correct type of lube to use on the shaft? 3 in one oil? Or a lithium type grease? Any thoughts are welcome. I"m just glad it"s running again! I use it to plow snow and here in MN you can"t go to long with a broken tractor for plowing snow. Thanks again guys. I love this forum. Paul |
| old
12-30-2012 13:23:50
209.86.226.34
Re: WD starter switch is sparking in reply to PTG in MN, 12-30-2012 10:12:09
| On the starter drive you want NO LUBE of any kind. To clean spray with brake cleaner spray because it leave the least residue behind and you want the starter drive area clean and shiny. Grease and oils collect dirt and dust which in turn makes the drive stick and that in turn causes problems like you had |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
