Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Too many oil compartments!
[Show Entire Topic]  [Return to Forum]
willie in mn
12-29-2012 02:41:21
67.142.168.22
Ralph
First off, there is no need for Hy-Tran in a WD or WD45.
Forward most compartment/drain is the hyd & belt pulley drive area. Uses regular hyd oil, doesn't need hy-tran as no heavy loads here. The filler for this area is the one on left side, by clutch pedal, with a dipstick under the cap. Don't remember how much it holds.
Second, third, & fourth drain are PTO, hand clutch, trans, & diff, all connected. Use regular gl 1 or gl 5, 80W-90, or even 80W-140. IIRC takes 17 quarts. Two filler plugs, 3/4 square heads along left side of trans/diff case. Hint- if you don'thave an 8 point socket for square headed bolts or pipe plugs, use a 12 point socket 1/8 larger than the square: 5/8 12 pt fits 1/2 sq, 7/8 12 point fits 3/4 sq, etc. Can fill completely using one fill plug, but takes a long time for oil to flow past divider, quicker to fill both plugs.
Caution- PTO housing is the lowest point, any water from condensation will collect here. If it freezes it will break & push the bottom right off.
Might not need to buy new oil. If not excess water in it, filter it thru one of those red gas funnels, with the brass screen. I have one that the screen is fine enuff that it will let gas thru, but not water.
I'm aware you knew all this, but might be handy for some of the newbies out there. How's that for a disclaimer?
Willie
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
