Yesterday's Tractor Co. Compare our Prices For Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: WD starter switch is sparking
[Show Entire Topic]  [Return to Forum]
John T
12-28-2012 18:09:39
216.249.82.117
On the side of the starter (under the switch)is the big copper button/contact and its to that the starter switch engages. If that has gotten all burned carboned and/or pitted or worn down too much even a hundred new switches wont fix the problem. Its takes BOTH a good switch andddddddddd a good non pited not worn down non carboned up starter button/contactor.
If things got too hot and arcing under that switch solder may have melted inside the starter resulting in open connections or mechanically stuck/jammed brush holders or burned commutator segments and all other sorts of nasty stuff.
High current draw may have also caused burned carboned resistive connections at battery post and terminals and ground connections and switch to cable connections etc etc. You may have to remove, clean n wire brush, and re attach each n every battery n starter and ground and cable connection.
So you need a good switch,,,,,,,,a starter with no internal damage,,,,,,,,a starter with a not worn out or burned or pitted or carboned button/terminal,,,,,,,,good cables and grounds and connections.
Of course, its possible for a starter to get mechanically stuck/jammed into the flywheel and that causes extreme high current draw which may have damaged the starter or caused burned or carboned connections etc. If you loosen the starter and/or rock the engine over it may free it up...
John T
[Reply]   [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
