TractorLinks.com
Show Parts for Model:
Re: WD45 Ignition/Charging Questions
steve(ill)
12-26-2012 18:39:25
If you leave 12 volts to the coil (key on ??) when the motor is not running, with the point closed, you get a constant battery drain and things get hot. 14.8 volts is good, 30 amps is only needed with the battery dead. If it stays at 30 amps for more than 5 minutes after you startup, then you have a voltage regulator problem . ( it should drop to 20, then 15 amps, etc down to 10 amps in 10 minutes). ---Old coils can cause a miss fire. Get a good coil then test.
