Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: D-17 Pressure Plate Adj.
BushogPapa
12-26-2012 10:06:35
Why would they need to be adjusted..??
Is the clutch "Stuck" and will not release..??
Adjusting the fingers will not help with that..
A failed clutch-plate (loosing lining in spots) will make the Pressure-plate fingers look out-of-adjustment...
Ron..
eye4iron
12-26-2012 18:09:09
 Re: D-17 Pressure Plate Adj. in reply to BushogPapa, 12-26-2012 10:06:35
Fairly new disc. Too much free play. I should have checked the finger height when I had it split.
BushogPapa
12-26-2012 19:05:31
 Re: D-17 Pressure Plate Adj. in reply to eye4iron, 12-26-2012 18:09:09
Must be a good deal of clearance...
If you are sure the Throwout bearing is correct...
Seems unlikely that the fingers would need adjusted, normally....
Hope you have it in where it will be warm and dry..!
Ron..
