TractorLinks.com
Show Parts for Model:
Re: Wd45 won't without choke
old
12-23-2012 11:59:00
Just because gas flows good does not say much since you have not given enough info for use to help you help your self. Gas flows but where. Carb drain plug or fuel line or where. If it flows good out of the drain plug then remove the main jet there should be a needle that you can adjust then a nut that locks/holds that needle then a bigger nut sort of thing. Remove the bigger one and make sure you have a good flow there and also that the needle area of that part is not clogged up
Wet in ny
12-23-2012 16:13:40
 Re: Wd45 won't without choke in reply to old, 12-23-2012 11:59:00
Flow is good from the bottom of the carb
old
12-23-2012 16:22:07
 Re: Wd45 won't without choke in reply to Wet in ny, 12-23-2012 16:13:40
Ok so pull the main jet adjustment nut and make sure you have a good flow there also. If you do not then the main jet is clogged and it will not run well if it is
