TractorLinks.com
Show Parts for Model:
Re: Cold starting tractor problem
ed in cny
12-20-2012 10:41:18
Old, part of the problem with the electric is that it was removed and then cobbered back in. It will not charge. I don"t have a battery to put in for it to turn over either at this time. Lastly it isn"t on my to do list just yet. I guess I got used to cranking and it works well enough to not bother.
old
12-20-2012 12:28:44
 Re: Cold starting tractor problem in reply to ed in cny, 12-20-2012 10:41:18
So then it has a mag so that is both good and bad. Does the impulse work as it should on the mag?? As for a battery you could just use jumper cables from your car or truck to spin it over no charging system needed on the tractor that way and you get a n easy start. If you can not get close to it take the battery to it one or 2 starts will not hurt your car or truck battery so you get the tractor running plus be able to drive home to boot. On my place I have few batteries but lots of machines so I play musical batteries all the time
