TractorLinks.com
Show Parts for Model:
Re: d14 lift cutout?
Too Far Gone
12-20-2012 10:27:56
It sure dont need to be any faster.It sounds like you'd have to break it in two for an adjustment or replacement of relief valve?How much should it lift before kickout?
Diydave
12-20-2012 16:28:58
 Re: d14 lift cutout? in reply to Too Far Gone, 12-20-2012 10:27:56
I suggest you beg borrow or rent a hydraulic flowmeter and guage, with a capacity of 5GPM @3500 PSI. Plug it into the remote, if it has one. Otherwise check the shop manual, for the test port location. Pump is a 4 piston type, runs on a cam, from the engine to the PD clutch. To pull pump is a no-split proposition, but if the cam lobes are wore off, you have to split it. There is no set weight, AFAIK, that it should lift. Pump should put out at least 4 GPM @ 3500 psi. You might have some debris on the suction screen, or a hinkey relief valve.
