Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Cold starting tractor problem
old
12-20-2012 09:55:13
First off I'll ask what the electric problem is. Is the starter burned out or just bad wires??? If just bad wires or the starter button bad remove the button and then take a heavy battery type cable or jumper cable the go from the battery to the starter stud and spin it over that way. Most of these old hand start tractor give a guy fits when warm, I am lucky if my JD-B 1935 modal will start it warm but mos of the time starts pretty easy cold unless it is very very cold out an then with the 50W oil in it forget about it LOL
ed in cny
12-20-2012 10:41:18
 Re: Cold starting tractor problem in reply to old, 12-20-2012 09:55:13
Old, part of the problem with the electric is that it was removed and then cobbered back in. It will not charge. I don"t have a battery to put in for it to turn over either at this time. Lastly it isn"t on my to do list just yet. I guess I got used to cranking and it works well enough to not bother.
old
12-20-2012 12:28:44
 Re: Cold starting tractor problem in reply to ed in cny, 12-20-2012 10:41:18
So then it has a mag so that is both good and bad. Does the impulse work as it should on the mag?? As for a battery you could just use jumper cables from your car or truck to spin it over no charging system needed on the tractor that way and you get a n easy start. If you can not get close to it take the battery to it one or 2 starts will not hurt your car or truck battery so you get the tractor running plus be able to drive home to boot. On my place I have few batteries but lots of machines so I play musical batteries all the time
