Yesterday's Tractor Co. Affordable Parts, Just in Time
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: Allis Chalmers b please help
[Show Entire Topic]  [Return to Forum]
old
12-19-2012 15:49:43
209.86.226.34
Not getting fuel to all but one cylinder is most likely sticking rings and or sticking valves so the compression is way to low to have any vacuum to pull the fuel into the cylinders on the intake stroke. Simple way to maybe fix sticking rings is an ATF treatment. Simply put about a 1/4 cup of ATF in each cylinder and let it sit over night. For the valves and this only works for the exhaust is pour some ATF down the exhaust pipe after pour it in the cylinders
[Reply]   [No Email]
jeff-h01
12-19-2012 15:54:32
66.87.91.123
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 15:49:43
I took the valve cover off and they were all working properly...put some fresh oil on them as well
[Reply]  [No Email]
old
12-19-2012 16:15:06
209.86.226.57
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 15:54:32
One can not tell for sure that the valves are closing all the way just by looking at them. Only way to know for sure what is going on is a compression check and I'll stick to what I said you have low compression BTDT and I do many tractor that are fence row machines and bring them back to life and that is why I have had 30 plus tractors
[Reply]  [No Email]
jeff-h01
12-19-2012 17:52:36
66.87.94.12
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 16:15:06
I see...good to know...is there anything i can do to ensure they are working properly?
[Reply]  [No Email]
chalmersbob(pa)
12-19-2012 19:42:24
71.175.233.24
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 17:52:36
Remove all 4 plugs and turn the engine over with your thumb in the plug hole, 1 cylinder at a time. You should feel compression and air pushing out of each hole. If you have this, then you have some compression. Do the the Automatic tranmission luid 9ATF)thing as Old has told you. Don't rush it, it doesn't always happen over night. Squirt gas into each cylinder, reinstall the plugs and attempt to start it. To check timing, put your thumb in plug #1 hole (closest to the radiator) and crank the engine until you feel air coming out, then use a 12" long wire and put into the hole,on top of the piston, and crank until the piston comes to the top of the cylinder. Remove the 2 screws from the front of the mag and look at the position of the rotor. It should point to the timing lug at about 11:00.If it points elsewhere, your timing is off and must be reset by removing the 4 screws on the mag cover and reseting the gears. LOL Bob
[Reply]  [No Email]
old
12-19-2012 18:46:47
209.86.226.19
A good start is doing a compression test then go from there.
[Reply]  [No Email]
jeff-h01
12-19-2012 20:04:04
66.87.90.36
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 18:46:47
Ok thanks..i have a tester what should the pressure be
[Reply]  [No Email]
old
12-19-2012 20:46:36
209.86.226.11
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 20:04:04
On most engines 90psi is bear bones min that you want
[Reply]  [No Email]
jeff-h01
12-20-2012 04:45:52
66.87.90.36
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 20:46:36
Ok thanks
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
