TractorLinks.com
Show Parts for Model:
Allis Chalmers b please help
jeff-h01
12-19-2012 12:33:31
Howe do i tell if the kill button on a fmj ac mag is shorted out?
jon corbett
12-19-2012 15:08:01
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 12:33:31
i have to ask,how long since it ran?i ask because the rings will lose their oil seal.means no suction-no fuel to plugs,pull plugs- each cyl gets a squirt of oil spin motor over couple times.put them back inand try to start.ijust brought my 39b back to life after setting many years
jeff-h01
12-19-2012 17:55:52
 Re: Allis Chalmers b please help in reply to jon corbett, 12-19-2012 15:08:01
Its been sitting 3 or 4 years...squirted a little gas in each plug hole but i may put asquirt of oil in tomm...thank you fire the info
old
12-19-2012 18:53:08
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 17:55:52
Gas bad as it is a non lubricant and if the rings are sticking from rust you have just added a problem on top of another problem. That is why I said ATf in each cylinder so as to help lube the cylinder walls up and to free up the sticking rings. ATF is the first thing I do to an engine when I find a fence row tractor and most of the time I can get them back up and running in just a short time
jeff-h01
12-19-2012 14:08:09
Finally got spark but how do i set the timing? While removing everything I'm sure its off...it only hits on one cylinder but is a backfire instead of a fire...it also only hits on the one cylinder seems like the other three aren't getting fuel..any suggestions?
bg/mo
12-19-2012 19:20:59
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 14:08:09
go to your local farm supply store and buy a service manual for the tractor , will help you more than you know, things as timing are hard to explain over the computer. Your question about the kill switch, just unhook the wire going to the mag and that will eliminate the switch.
jeff-h01
12-20-2012 06:25:54
 Re: Allis Chalmers b please help in reply to bg/mo, 12-19-2012 19:20:59
There is no wire its a little push button type kill switch...but i got spark now and ruled that out..good idea on the manual thanks
old
12-19-2012 15:44:55
As I said before send me an e-mail and I'll send you the manual for that mag. Only thing it cost you is your time so send the e-mail and ask then with it manual you have ALL the info you will ever need to work on that mag. Or is that maybe to hard for you to do???
Rod (NH)
12-19-2012 14:42:55
Perhaps this will help you out.
Rod
jeff-h01
12-19-2012 14:46:26
 Re: Allis Chalmers b please help in reply to Rod (NH), 12-19-2012 14:42:55
Thanks rod seems very simple...would u have any recommendations as too not getting Any fuel to the number 1,3,4 cylinders?
old
12-19-2012 15:49:43
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 14:46:26
Not getting fuel to all but one cylinder is most likely sticking rings and or sticking valves so the compression is way to low to have any vacuum to pull the fuel into the cylinders on the intake stroke. Simple way to maybe fix sticking rings is an ATF treatment. Simply put about a 1/4 cup of ATF in each cylinder and let it sit over night. For the valves and this only works for the exhaust is pour some ATF down the exhaust pipe after pour it in the cylinders
jeff-h01
12-19-2012 15:54:32
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 15:49:43
I took the valve cover off and they were all working properly...put some fresh oil on them as well
old
12-19-2012 16:15:06
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 15:54:32
One can not tell for sure that the valves are closing all the way just by looking at them. Only way to know for sure what is going on is a compression check and I'll stick to what I said you have low compression BTDT and I do many tractor that are fence row machines and bring them back to life and that is why I have had 30 plus tractors
jeff-h01
12-19-2012 17:52:36
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 16:15:06
I see...good to know...is there anything i can do to ensure they are working properly?
chalmersbob(pa)
12-19-2012 19:42:24
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 17:52:36
Remove all 4 plugs and turn the engine over with your thumb in the plug hole, 1 cylinder at a time. You should feel compression and air pushing out of each hole. If you have this, then you have some compression. Do the the Automatic tranmission luid 9ATF)thing as Old has told you. Don't rush it, it doesn't always happen over night. Squirt gas into each cylinder, reinstall the plugs and attempt to start it. To check timing, put your thumb in plug #1 hole (closest to the radiator) and crank the engine until you feel air coming out, then use a 12" long wire and put into the hole,on top of the piston, and crank until the piston comes to the top of the cylinder. Remove the 2 screws from the front of the mag and look at the position of the rotor. It should point to the timing lug at about 11:00.If it points elsewhere, your timing is off and must be reset by removing the 4 screws on the mag cover and reseting the gears. LOL Bob
old
12-19-2012 18:46:47
A good start is doing a compression test then go from there.
jeff-h01
12-19-2012 20:04:04
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 18:46:47
Ok thanks..i have a tester what should the pressure be
old
12-19-2012 20:46:36
 Re: Allis Chalmers b please help in reply to jeff-h01, 12-19-2012 20:04:04
On most engines 90psi is bear bones min that you want
jeff-h01
12-20-2012 04:45:52
 Re: Allis Chalmers b please help in reply to old, 12-19-2012 20:46:36
Ok thanks
