Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Allis Chalmers b
12-18-2012 17:09:51
I'm not sure which one it has...its a 39 serial number b32474 if that shut it off it has a little thing on the side to ground it sorry not much info
12-18-2012 17:31:13
 Re: Allis Chalmers b in reply to jeff-h01, 12-18-2012 17:09:51
Look on the mag it should have some info on it. There was 2 common mags used on the A/C tractors. So if you send me an e-mail and I send you the wrong one just let me know and I can send the other one.
12-18-2012 18:07:39
 Re: Allis Chalmers b in reply to old, 12-18-2012 17:31:13
Sounds great...won't be able to untill tomm afternoon as it is at my dads...also what's a good asking price for one? It was a raffle tractor about 12 yrs ago complete restoration never been outside all tires are good really just needs washed also has cultivators on it...i was asking that fair?
12-18-2012 19:03:10
 Re: Allis Chalmers b in reply to jeff-h01, 12-18-2012 18:07:39
Probably a Fairbanks Morse FMJ magnito, as these were the most common on a AC B or C tractor.To clean the points, remove the cap that has 2 screws, and take note of where the rotor bug is pointing at, then remove the 4 scrws holding the bakelite cap on.After exposing the points, go sneak the wife's sandpaper nail board, out of the house, and insert it between the closed points, and sand them shiney. Blow all sand out of the magnito, and reinstall the bakeite cap,MAKING SURE THAT THE ROTOR STILL POINTS WHERE IT DID PREVIOUSLY. This assumes that you didn't rotate the engine during the above actions. replace the cap with 2 screws, and try for fire. If no fire then your condenser or coil is bad, or the kill switch is grounded out. Good luck
12-18-2012 19:14:21
 Re: Allis Chalmers b in reply to Ralphwd45, 12-18-2012 19:03:10
Now that u said it remember it saying Fairbanks Morris on it...i know about not turning the engine while apart...i have a Farmall f-12 and f-14i had to do work to..thanks for the help
